I am concerned the jet will therefore be too low to perform the initial setup - is it a prolem that I can't raise the jet level with the bridge, and if so - what is the likely cause?
The jet is a new waxstat.
Thanks for any help!
EDIT:
After looking at it for an hour, I just realised that by pushing it up flush and doing the nut adjustment it is irrelevent as it brings the adjustment nut low enough. Damn me for posting too early...
EDIT 2:
Still an issue - whilst I can set the jet height to the correct initial setup, if I rotate the choke cam and let it spring back, the spring doesn't seem strong enough and the jet returns to a lower level. Can this normally be resolved using vaseline/WD40 etc or does it normally mean spring replacement etc?
Edited by Shylos, 25 March 2013 - 04:53 PM.
