Dies After Revving
Posted 27 March 2013 - 05:37 PM
Got my 998 auto 1990 standard set up started after 6 months idle.
Changed air filter plugs. Leads. Adjusted points new dizzy cap.
Fired up after loads of cranking piggy backed off a running car with jump leads.
got it warm and was idling fine, but when i rev and let revs drop, it drops to a point where it can't keep running and it stalls.
The only way to rev it and keep it going when the revs drop is to slowly nurse it down to idle speed.
Any ideas?
Posted 27 March 2013 - 07:45 PM
Posted 28 March 2013 - 09:20 AM
Posted 28 March 2013 - 10:33 AM
You problem sounds like an air leak at the carb (check vauum pipes, breathers etc) or overfuelling.
Posted 28 March 2013 - 10:59 AM
Posted 28 March 2013 - 11:19 AM
Also, the centrifugal advance mechanism in the distributor could be sticking, but carb is far more likely. Check the distributor anyway, it only takes a minute. Twist the rotor arm (it will only move significantly in one direction). If it springs back when you release it, it is most likely ok.
Another possibility (and yes, it has happened to me, on two different cars, one a Mini) is that there is friction somewhere in the throttle mechanism, cable etc, so that it does not go right back tight against the adjusting screw when you think it has, but when you release the pedal from high revs, it goes back fully, and the idle speed adjustment is just too low, so it stalls.
Posted 28 March 2013 - 01:27 PM
Posted 28 March 2013 - 03:06 PM
I had to jump it off my scenic because the 2 min of cranking without success was flattening the battery.
It just need a hand off of a diesel car battery with more CCA.
A would a poor earth cause the problem with the engine dying?
Posted 28 March 2013 - 07:59 PM
Engines which are runing weak do have tendency to stall when you drop the revs, have you checked the intake manifold gasket and carb for air leaks with wd40?
Posted 28 March 2013 - 09:10 PM
How would one check with wd 40?
Posted 28 March 2013 - 09:21 PM
Edited by KernowCooper, 29 March 2013 - 01:12 AM.
Posted 29 March 2013 - 01:04 AM
