Track Rod Arms.
Posted 29 March 2013 - 07:55 PM
is it true you can not change the track rod arms.
i have a little bit of play in my track rod arm. hardly anything at the moment,
but i can seem to find to a replacement part which must mean that the arm is not removable.
is this correct? before i buy a steering column .
Posted 29 March 2013 - 07:59 PM
what the track rod end attaches to.
Posted 29 March 2013 - 08:02 PM
Iirc the steering rack can only be bought as a complete unit, no parts are available separate but I could be wrong.
Ben
Posted 29 March 2013 - 08:04 PM
Posted 29 March 2013 - 08:15 PM
the play atm is very very minimal. will grease it all up an see what happens.
Posted 29 March 2013 - 09:07 PM
great. another great design by British Leyland.
Track control rod from steering rack to track rod end (bearing) ? just get a new rack it will be a lot better in the long run, and there are not many racks that can be repaired, most are either throw away or require very special equipment.
Posted 29 March 2013 - 09:12 PM
The play in the LH track rod (NOT track rod END) is normally in the bush which sits inside the rack outer tube.
You can only change these by taking the rack out and completely stripping it down. Therefore, you will be best off getting an exchange rack. In fact, I don't think the bush is available now. Part number is 37H8064.
Posted 29 March 2013 - 09:57 PM
Posted 29 March 2013 - 10:03 PM
We did this on the rally cars as the felt bush would fail very quickly on an early rally Mini. With the 3 nylon bushes the rack would last a long time without any problem.
Posted 29 March 2013 - 10:07 PM
I have re-built original racks, back in the 60's & 70's, but it's really easier to buy a brand new one as when rebuilding the setting up is critical.
Edited by Cooperman, 29 March 2013 - 10:08 PM.
Posted 29 March 2013 - 10:15 PM
Posted 29 March 2013 - 10:16 PM
Posted 29 March 2013 - 10:18 PM
