Hi I have converted from points to aldon electronic ignition so will I have to make my plug gap size bigger? if so what is the size? i know normally is 0.8mm and the plugs are Champion N9YC
Electronic Ignition
greensilver mini
, Mar 30 2013 12:01 PM
2 replies to this topic
Posted 30 March 2013 - 12:01 PM
Posted 30 March 2013 - 12:16 PM
I have the same Aldon on mine and I am running 30thou (0.762mm) The standard plug gap is 25thou (0.635mm) so if your on 0.8mm (31.49thou) now thats over standard and my opened up gap? I dont think you need go any bigger, and remember by increasing the plug gap the rest of the ignition system (Leads/Coil/Cap/Rotor) needs to be in tip top condition.
You could experiment by going bigger and see what results to get, any signs of misfiring indicates the limit of your ignition.
Edited by KernowCooper, 30 March 2013 - 12:18 PM.
Posted 30 March 2013 - 12:28 PM
ok thank you
