Project Arkie
33 replies to this topic
#16 miniweights
miniweights
  • 202 posts
Posted 21 April 2013 - 06:18 PM
Started to fit the rear wiring loom today. Added extra some cables for reversing and fog lights, rhs and fuel pump. And luckily it all fitted through one fireproof gland.
#17 steven
steven
  • 1,195 posts
Posted 21 April 2013 - 08:03 PM
looks so tidy !
#18 F1L8EY
F1L8EY
  • 600 posts
Posted 21 April 2013 - 08:59 PM
Was Saltash but have recently relocated over the border in plymouth :X work down your way in helston though!!
you going to be up at the Riviera ??
#19 miniweights
miniweights
  • 202 posts
Posted 25 April 2013 - 05:47 PM
That's a bit of a way go. Helps me appreciate working from home. Will probably go to Riviera and have a nosy for a couple of hours, and then get back on with building the mini :-)
#20 Alex_B
Alex_B
  • 4,573 posts
Posted 25 April 2013 - 06:18 PM
Really impressive build, I love the dash thats something else! will be watching this one!
#21 miniweights
miniweights
  • 202 posts
Posted 06 May 2013 - 06:28 PM
Cheers Alex. Been busy re-routing and adding cables. Also extra gauges, and fitting a battery master cut-out switch...Very therapeutic wiring :D
#22 miniweights
miniweights
  • 202 posts
Posted 12 May 2013 - 04:07 PM
Got a little bit more done this weekend. Wiper motor has only a single speed, so decided to add the third motor brush (yellow wire) to make it a two speed motor while i'm giving it a bit of a tidy up.
Ready to fit back in...Just need to fit a two speed switch and an extra cable now  :D
#23 miniweights
miniweights
  • 202 posts
Posted 17 May 2013 - 05:54 PM
Done a bit more with the dash this week.
Now that I've decided to make the centre extension separate from the rest of the dash, I made up the shape using some plastic sheet cut to the size and shape I wanted. Then held it together with some gaffa tape.
Next I sprayed the inside surface with some release agent. Then I spread a layer of fibreglass bridger on the inside surface.
Had to put a bit of filler on to level out the surface as the heat of the fibreglass resin warped it slightly.
Meanwhile I decided to cover the main part of the dash with some leather textured vinyl fabric. Hopefully giving it a textured surface, it should help stop the light reflecting off the surface.
I've only glued the front on so far as I want the glue to set properly before I try to stretch it around the top and bottom.
So far so good. Once this is finished I will be able to make a mould of it :D
#24 pickup72
pickup72
    Starting My Mini Up
  • 1 posts
Posted 17 May 2013 - 07:27 PM
nice work
#25 jackx998
jackx998
  • 264 posts
Posted 17 May 2013 - 10:47 PM
Looking good mister, keep it up =]
#26 miniweights
miniweights
  • 202 posts
Posted 23 May 2013 - 06:40 PM
Bit of a tight stretch to glue the top part, so had to clamp it in place :unsure:
#27 miniweights
miniweights
  • 202 posts
Posted 24 May 2013 - 05:00 PM
Getting there...Slow but sure
#28 lawrence
lawrence
  • 1,341 posts
Posted 24 May 2013 - 05:37 PM
I'm liking that dash buddy, should look pretty good ones she's got some retro dials fitted too, keep up the good work!
#29 mini=love
mini=love
  • 211 posts
Posted 24 May 2013 - 06:30 PM
Looks good lets hope you have some good glue under there. I did my dash like that a while back but it didnt keep in place for to long.
#30 miniweights
miniweights
  • 202 posts
Posted 24 May 2013 - 07:50 PM
Cheers guys, hoping it will glue ok, I'm using that spray carpet glue...very sticky, and goes everywhere :ohno:
