Points
Posted 04 April 2013 - 05:24 PM
Thought i had a bad HT lead so i bought some new ones and plugs fitted them and it was still a bit rough.
Cousin came round and we re-set the points and now its fine. I'm sure i read that the BLUE points had a bad batch or not so reliable. Can you buy better versions of points or would it be better to fit a electronic conversion kit?
Cheers.
Posted 04 April 2013 - 05:28 PM
Posted 04 April 2013 - 05:38 PM
Posted 04 April 2013 - 05:49 PM
Posted 04 April 2013 - 05:50 PM
Just to clear something up,my coil is a ballast type so fitting a electronic kit, the red wire from the kits would need a power source straight from the fuse holder,is that right?
Does it matter which side of the fuse you use and it needs to be a power source with ignition on only??
Thanks.
Posted 04 April 2013 - 05:52 PM
Posted 04 April 2013 - 05:54 PM
Right cheers guys,
Thanks.
It needs to be fed from a ignition swiched 12v feed on the fuse box if your keeping the ballast coil setup
Posted 04 April 2013 - 06:00 PM
Seems someone might have an issue, so i will keep watching and see the other side (no offence to anyone!)
Posted 04 April 2013 - 06:14 PM
OK got that.
Seems someone might have an issue, so i will keep watching and see the other side (no offence to anyone!)![]()
Sorry venkman you;ve lost me ?
Posted 04 April 2013 - 07:00 PM
You had 100% reliability, how long have you had it on?
Posted 04 April 2013 - 07:58 PM
I will be selling it along with the ignition coil when I get a chance. Only reason for sale is I've moved onto a 3D mappable system (Nodiz).
Posted 04 April 2013 - 08:31 PM
What problems did you have with the Powersparks/Accusparks ? were they wired correctly at the coil / and the wiring modified to suit? I have a Aldon in mine and its 100% reliable
Well with the accuspark one I had to modify the magnetic ring so it actually sat on the cam properly, and only lasted a week and a half before it started misfiring and ripped my cap apart. And the powerspark version didnt even work, following all of the installation instructions and making sure all connections were correct, but nothing happened, so I instantly swapped back to my points
Posted 04 April 2013 - 08:32 PM
Posted 04 April 2013 - 09:15 PM
min ritz ryan said earlier that he had problems with a couple and i was hoping to find out what problems he had had.
been on the car about 4years
Posted 05 April 2013 - 02:11 PM
The reason i started this post is because the car has been on the road for 6-7 weeks and the points needed adjusting,is this about the norm?
Thats why i wondered if you could buy better quality points or go electronic.
