Indicators
Posted 04 April 2013 - 06:05 PM
Posted 04 April 2013 - 06:11 PM
Posted 04 April 2013 - 06:14 PM
Not strange - top fuse is my guessWhat colour wire are the indicators on the stalk? Mine have stopped working along with brake lights for some strange reason
Main fuses (four-fuse fuse block - later models)
Fuse connecting Rating (amp) Circuits protected
1 and 2 35 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stop lights, reversing lights, direction indicator relay, heated rear window, headlight dim-dip relay. These systems will only operate with the ignition switch at position ll
3 and 4 25 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Horn, headlight flasher, brake failure circuit, radio memory. These systems operate independently of the ignition switch
5 and 6 25 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Heater blower motor, windscreen wipers/ washers, instruments. These systems will operate with the ignition switch at position I or ll
7 and 8 15 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Left-hand side and tail lights, instrument panel lights, headlight dimdip relay
Posted 04 April 2013 - 06:16 PM
Thanks but I dont really understand that?Not strange - top fuse is my guess
Posted 04 April 2013 - 06:19 PM
Posted 04 April 2013 - 06:21 PM
Posted 04 April 2013 - 06:24 PM
Green/white is Indicator Right
Green/Red is Indicaror Left
Brake light is Green Purple
Edited by KernowCooper, 04 April 2013 - 06:24 PM.
Posted 04 April 2013 - 06:26 PM
Right here we are courts
Thanks, I cut the purple wire and was worried it was the indicators.
Posted 04 April 2013 - 06:27 PM
The top fuse in the fuse box on the bulkhead (under the bonnet) powers the stop lights (brake lights) and the indicator relay, along with heated rear screen and reverse lights - check if your heated screen works - if not, you have a dodgy fuse.
No indicators, brake lights or reverse lights
Posted 04 April 2013 - 06:30 PM
Posted 04 April 2013 - 06:34 PM
Posted 04 April 2013 - 06:40 PM
Where was the purpule you cut? for reference purple is used on the headlight flash switch
Edited by KernowCooper, 04 April 2013 - 06:43 PM.
Headlight
Posted 04 April 2013 - 06:48 PM
Posted 04 April 2013 - 06:59 PM
Visually check the fuse, but remember they are different amps so not swapible, but to sucessfully diagnose and fix electrical faults you do really need a volt meter, otherwire its guess work
The flash still works though?
