Problem 1 is that one pad is touching the disk and the other has a few mm of clearance.
Problem 2 is the other caliper where the metal lip which holds in the seal isn't flush with the surface, so I can't even get the disk in....
Thoughts and advice welcome?
Should I just send both calipers back??
