My 1989 mini alternator has given up, I'm looking for a replacement and have narrowed it down with the Haynes manual to "Lucas A127/45 or A127/55"
I'm unsure of the amp I need, can I simply replace it with the larger one and it will make no odds? Or do I have to put in a new battery and electronic systems to upgrade to the 55 amp?
Alternator Replacement
CFB0800
, Apr 07 2013 11:10 AM
8 replies to this topic
Posted 07 April 2013 - 11:10 AM
Posted 07 April 2013 - 11:23 AM
no will be fine.
run the 55 amp one.
freaker
run the 55 amp one.
freaker
Posted 07 April 2013 - 11:24 AM
I've just looked its the 45 but I can just swap for a 55 and everything will still run fine?
Posted 07 April 2013 - 11:27 AM
yes no problem
freaker
freaker
Posted 07 April 2013 - 11:39 AM
Is it also a simple swap if you put an 80 amp one in?
Posted 07 April 2013 - 12:47 PM
Yes- but if you're going with a higher current, best to chack the basic charging wiring circuit is in good condition - braded earth cables and battery +ve to solenoid inparticular. Bit of a waste otherwise.
Posted 07 April 2013 - 03:24 PM
No, if you are going to fit a much higher power alternator than the wiring was designed for like that (the 75A or more types I mean) you should increase the size of the cables from the alternator to the starter solenoid. This is the only part of the system that will need improvement.
Posted 07 April 2013 - 03:51 PM
Just going by what I was told back along, no intent of misinforming.
Posted 07 April 2013 - 03:58 PM
Well, at 55A the wiring is still ok, just, so I don't think there was any disinformation, but at 75A you very definitely do need to upgrade the wiring, the thick brown wires from the alternator to the battery terminal on the starter solenoid only. 55A is adequate for most cars anyway.
