Fititng A New Rear Subframe
Posted 07 April 2013 - 12:45 PM
I've just been having a look under the car to see where to support it. At the moment it is up on axle stands (but they are on the sub frame).
Any help would be greatly appreciated.
Adrian
Posted 07 April 2013 - 12:50 PM
Posted 07 April 2013 - 12:51 PM
Posted 07 April 2013 - 12:52 PM
once that's out the road, get a good strong plank, I have a short scaffold plank.
put the plank under the car just in front of the heelboard (where the subframe bolts on) then put your axle stands under the plank.
If no plank then a couple of thick wood boards about 18" sq to spread the load
Posted 07 April 2013 - 01:04 PM
A big plank of wood across the floor, just in front of the heel board, axle stand at each end.
axle stands under rear of floor with some wood to spread the weight.
There is an echo in hereIf you haven't already remove the exhaust.
Posted 07 April 2013 - 01:06 PM
Posted 07 April 2013 - 01:18 PM
Too slow!!!!!! (Makes a change, usually other way round)that's cause you hit send first :) we must have all been typing :)
Posted 07 April 2013 - 01:29 PM
Same thing at the front, if you want to drop the subframe, quite often only partially to change the steering rack. The wood goes right at the front of the floor, as close as possible to the toeboard.
Worth keeping a bit of suitable timber in the garage, as you will need it again, hopefully not too soon!
Posted 07 April 2013 - 02:43 PM
I am new to the forum, posted two questions today and received good quality answers.
Thanks again.
Posted 07 April 2013 - 02:59 PM
