Noobie Wiring Worry
Posted 10 April 2013 - 05:40 AM
Posted 10 April 2013 - 05:57 AM
Posted 10 April 2013 - 06:20 AM
Posted 10 April 2013 - 06:44 AM
Also, what amp will you be using?
Edited by Badboytunes, 10 April 2013 - 06:44 AM.
Posted 10 April 2013 - 07:10 AM
Posted 10 April 2013 - 08:47 AM
Posted 10 April 2013 - 12:46 PM
If you can post the model number of the amp then you can get a clearer idea of what (if anything you will need) as amps have a rating to how efficient they are, less efficient need more power to generate the same signal hence more drain.
In regard to alternator and battery, you only need upgrade your alternator if it cannot cope with the load placed upon it, you say the amp has a max 30amp draw - that is at absolute max volume, if you have a 55amp alternator then that leaves you 25amp (at perfect condition) to power the car, add lights and heater to that you might be pushing the limits BUT and it's a big one, how often are you going to run your amp at 100% with lights and heater on?
For the moments when the alternator isn't quite up to the job, that's when your battery steps in to take the excess load.
You can if you wish calculate the draw on your system and decide if you need a larger alternator or you can try yours and see how it goes before sinking cash into parts.
Regarding batteries, again you don't need one unless yours currently isn't able to start the car or you are planning on running your new system for lengths of time without the car running, in which case a deep cycle battery would be a better option to be sure you can actually start the car again on 10% charge.
Where are you fitting your amp? You don't need 0 gauge cable. 0 gauge is good for north of 3000 watts on a 15 foot run.
You can calculate the numbers yourself here:
http://www.bcae1.com/
Or with detail of where the amps / speakers will be mounted and the model numbers we can help you.
Posted 10 April 2013 - 03:39 PM
I would fit it with the correct gauge wiring (8awg with a 50amp fuse) and see how you go, if you find that the alt struggles with the amp use with lights/heater etc. then think about larger battery or alt.
In my opinion you wouldn't need anything more as long as battery and amp are in full working order.
Posted 10 April 2013 - 04:59 PM
Thanks again all
Posted 10 April 2013 - 05:03 PM
Posted 10 April 2013 - 05:27 PM
