Replaced Alternator And Won't Start
37 replies to this topic
#1 CFB0800
CFB0800
  • 21 posts
Posted 10 April 2013 - 02:33 PM
I have just replaced my 45amp alternator for a 55amp after being told on here it would be fine, I have just tried to start her and she is turning over and everything but won't spark into life, also the little red light that shows oil pressure has came on and won't go off
#2 Barman
Barman
  • 1,068 posts
Posted 10 April 2013 - 02:37 PM
Logic tells us you have disturbed some cables while fitting the alternator....
#3 CFB0800
CFB0800
  • 21 posts
Posted 10 April 2013 - 02:39 PM
Okay I will go look at all the cables! Is there anything else it could be?
#4 Archa
Archa
  • 293 posts
  • Local Club: Essex Mini Club
Posted 10 April 2013 - 02:47 PM
My thought also, literally look at everything you have touched while fitting the new alternator.
#5 Barman
Barman
  • 1,068 posts
Posted 10 April 2013 - 02:49 PM
Well, you can unplug the new alternator and check that it is not causing the problem....
If not, you must have moved a cable off the coil, dizzy, etc.
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 April 2013 - 03:09 PM
The red light is the alternator charging light not the oil light, I would check for any wires you may have disturbed on the coil, have you checked for spark at the plugs?
What engine are we talking about? electronic/points?
#7 CFB0800
CFB0800
  • 21 posts
Posted 10 April 2013 - 03:37 PM
It's a 998 and it's running but only when I remove the bottom cable from the alternator (i think it's the earth) what does this mean? Will my battery not be charging anymore?
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 April 2013 - 03:42 PM
Bottom cable? You should have 1 large plug with three terminals for your alternator, and it shouldn't be earthed by a cable at all. What Mini is this? What colour cables are there?
#9 CFB0800
CFB0800
  • 21 posts
Posted 10 April 2013 - 03:51 PM
Dan,
It's a mini thirty and there is the main plug with the three wires running to it and there is a singular cable below it (black and yellow)
#10 CFB0800
CFB0800
  • 21 posts
Posted 10 April 2013 - 04:47 PM
There is a cable below my 1989 mini thirty 55 amp alternator it has the main three pin plug and this cable below
When I plug this in the engine cuts out? What does this mean?
#11 lrostoke
lrostoke
  • 6,923 posts
Posted 10 April 2013 - 04:58 PM
what colours the cable ??
#12 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 10 April 2013 - 05:25 PM
any pics?
#13 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 April 2013 - 05:36 PM
Threads merged, please don't start numerous threads about the same problem.
There are no black / yellow cables on a Mini 30! Can you trace where it goes?
#14 lrostoke
lrostoke
  • 6,923 posts
Posted 10 April 2013 - 05:49 PM
At a guess I'm wondering if its a discoloured black/white.
The car hasn't been retro fitted with electronic ignition at any point as it ????
If that's the case it may be the old cable to the points ??? And no longer needed which would explain why it cuts out you'll be earthing the coil stopping the spark
#15 CFB0800
CFB0800
  • 21 posts
Posted 10 April 2013 - 06:33 PM
It is a discoloured white and black leading into a rolled tape of wires... When I connect this to the alternator it's cuts the engine, and when I put a volt meter on the battery when it's running it reads 11.77 volts (same when it's switched off)
