Hi all
So, finished the last of my rewiring this evening and have hit a snag... Got centre dials and trippled checked everything, everything is connected properly thru the voltage stabiliser, but turning ignition on the fuel gauge goes off the scale. It's only got 5ltrs in, so definitely a fault.
I've done the usual ground out the temp sensor wire and that gauge is fine, so just the fuel one.
I've swapped n the tank which made no difference, so I'm pretty convinced it's a shot sender as the tank has been off the car for decades (barn find).
Just wanted to check concencous before ordering.
Cheers.
Scott
Fuel Gauge
scott_65_cooper_s
, Apr 11 2013 08:58 PM
3 replies to this topic
Posted 11 April 2013 - 08:58 PM
Posted 11 April 2013 - 09:00 PM
Sorry should read "swapped terminals on the tank"
Posted 11 April 2013 - 09:18 PM
Can you give us a bit more info? What age is the car, what parts are new etc? A very early tank sender wouldn't be compatible with later gauges, and it would read in reverse I believe.
Posted 11 April 2013 - 09:25 PM
The car's a 65, but the tank may be later. The Speedo also isn't original, but again not new... Basically everything is varying degrees of used, which I know doesn't help, but being a 65 I should be later than the very early obsolete senders.
