I got the damn thing back in but most of the bolts didn't line up and then I realised one of the rubber gaiters had come off the knuckle joint ****! So I've taken it back out to refit it. A question here... is the type of grease critical on the knuckle joint? Most of the red stuff came off as I had to replace the rubber gaiter as I split the first one trying to fit the radius arm back in the subframe. I've got some wheel bearing grease, is that okay to use?
If you're about to do this job make sure you cable tie the radius arms to the subframe so they're in the up position before you try and refit it or guess what... the arm will drop and pull the rubber off the knuckle joint grrrrr.
Anyway, now that I've got the rant over with... when I got the subframe close to where it needed to be I noticed the shock absorber was about 4" short of the hole in the rear wheel arch where it needs to be. Is this just a case of jacking up the rear hub to compress the rear rubber cones? Virtually everything is new on the back... cones, bushes, shock absorbers etc.
Thanks, Paul.
Edited by PaulColeman, 12 April 2013 - 07:59 PM.
