Tyres Losing Air
Posted 14 April 2013 - 06:11 PM
Bought a set of wheels a while ago and have put them on a week ago,
One tyre goes down to 7psi in 3 days and the others go down to 25ish in 3days
There are no visable leaks or objects in the tyres, side walls look ok,
Could they need re-sealing?
Any other ideas it could be as would be nice if didn't have to get new tyres :)
Posted 14 April 2013 - 06:14 PM
Posted 14 April 2013 - 06:21 PM
I have the same issue and i've tracked mine down to a badly fitted valve.
You can put them in a bath or a bid tub but unless it's already full, you're using alot of water for no reason....unless you've got a swimming pool...which we all have of course!!!
Posted 14 April 2013 - 07:18 PM
I hope they are not damaged :/
Posted 14 April 2013 - 07:20 PM
Our local tyre place (ATS) sorted two of our Superlites that were doing this. Remove tyre, light grit rubdown and clean, then reseat the tyre, job done.
Posted 14 April 2013 - 07:21 PM
Posted 14 April 2013 - 07:22 PM
Posted 14 April 2013 - 07:43 PM
Posted 15 April 2013 - 05:03 AM
Posted 15 April 2013 - 08:13 AM
i usually find i had to clean the inner edges of the rim and paint, let dry then refit tyre.
Paint is the key to stopping them just corroding again
Posted 15 April 2013 - 11:40 AM
Posted 15 April 2013 - 12:02 PM
Posted 03 February 2014 - 09:02 AM
I've pumped it right up and dunked it in the bath but can't even see no bubbles after watching it for a while. Hope the wheel isn't bent
Edited by megamini_jb, 03 February 2014 - 09:03 AM.
