5 Speed Gear Boxes
Greg Davies
, Apr 21 2006 07:17 PM
7 replies to this topic
Posted 21 April 2006 - 07:17 PM
Just woundering if any one could help me find the best path to getting a 5 speed in the mini... ive got a 1964 mini which is going to be changed to remote gearbox shortly.. does any one know a cost effective way to having a 5 speed remote gear box in the mini? any help apreshiated, Thanks
Greg Davies
Greg Davies
Posted 21 April 2006 - 07:23 PM
not sure about cost effective but minispares do a 5 speed box for about 2 grand. i think Bungle has one.
Posted 21 April 2006 - 07:27 PM
i sent an email to vmaxscars and got a reply saying that for the moment they arent producing any 5 speed boxes and 2,000 is alot of money has any one any idea of any second hand gear boxes etc? saw a 5 speed on KADS website but no cost? thanks for ur pateience
Firstly, I don't think anyone's ever made a remote type 5 speed as the fifth speed gear uses the part of the box used by the shift mechanism in the magic wand/remote setup. The KAD gearset might fit as it all fits in the normal end of the gearcase but it's kind of designed for late gearcases and is very much a racing box. You'd have to check with them whether it's possible.
As for rod change versions, Mini Spares used to offer theirs as a kit to fit to your own gearbox in the past but I don't think they do any longer.
There is no quick fix for this really. All the 5 speed gearboxes produced are bespoke items and cost a lot of cash due to the high development costs and limited market. If you want a helical cut, synchromesh road type gearbox the only option new at the moment is the Mini Spares one as KAD & Jack Knight only make straight cut currently. I think Mini Sport have stopped theirs and V-max Scart definitely have. The Mini Spares road 5 speed will only take something like 85 lbft of torque.
The only other option is to find a second hand one and have it re-built. They are rare though.
Posted 21 April 2006 - 07:45 PM
The only other option is to use a K series Metro engine as they have 5 speed. But judging by your question I don't think this is going to be a very viable option.
To be honest I don't think 5 speed boxes are worth the outlay. IIRC, Guessworks stated that the 5th speed only lowers the revs by about 500rpm. The only reason I can think of for fitting a 5 speed box to a road car is for motorway miles, in which case you'd be better off fitting a taller FD.
Posted 21 April 2006 - 08:04 PM
Well if you're doing that you could fit any other modern engine but that's a bit extreme just to get an extra gear.The only other option is to use a K series Metro engine as they have 5 speed.
The problem with most of the 5 speeds is that they aren't built the way most modern gearboxes are. Rather than having a direct top and adding an extra speed in lower down the box they keep 4th as direct and add an overdrive on the end, and a pretty pathetic one at that. The KAD box is different, it has a true direct top speed and an additional speed added between 1 and 2, but all the low gears are much lower than standard. This means you can have a good FD for high top end speeds and still get good acceleration due to having a lower 1st gear. As I've said though the KAD box, although brilliant and well made is not great on the road. It's straight cut dog engagement only.
Posted 21 April 2006 - 09:03 PM
mines a jack knight box
and you cant have it >
Posted 21 April 2006 - 09:53 PM
I've seen a fair few 5 speed boxes gone pop - the overdrive 5th gear puts a lot of stress on small bearings..
the direct 1:1 5th gear is a better design - but at a price...
none of the 'regular' 5 speeds would fit into a remote gear case, as, (as dan has already mentioned) the overdrive gear sits in the side populated by selector shafts and stuff!
TTFN,
Dave
TTFN,
Dave
