Was checking tyre pressures tonight and found quite peculiar wear on my rear N/S tyre, bald on the outside with still healthy tread on the inside. The tyre as I remember is about 9 months old, so this is obviously quite aggressive wear.
I haven't smacked any curbs or similar, and the radius arm bearings don't appear to have play. Could someone point me to the cause of this, and maybe also the solution? If something is bent in the subframe, I suppose adjustable radius arm brackets are the only way to dial the +ve camber out?
