I've found the 12v feed on the solenoid but the bolt is to bit and I won't be able to get a safe connection there.
I've found on the fusebox that the second fuse down is live at 12v. It has 2 brown cables on the left side and a single smaller green/?? something on the other side with an unused spade. Will this be okay for the spot lights? The 12v cable for the spot lights has a fuse in it already which is a lower rating than that of the fuse box.
Can I also earth it through the horns earth?
E: It's a '91 998.
Edited by Camel, 18 April 2013 - 12:35 PM.
