A Little Help Please
Posted 19 April 2013 - 12:21 AM
first of, im pretty scared of doing this LOL
second, where do i start price wise?
thanks!
Posted 19 April 2013 - 12:51 AM
Second? Will cost more than you think.
What you thinking? Rear or front mounted? What engine? Gears? Reverse? What loom? Standard chassis or fresh space frame?
Atmo or turbo (or other forced induction) ?
Going for fast road or track?
Posted 21 April 2013 - 03:32 PM
First. Grow a pair. Do you have a *******? No? So you are male then....
ill be honest, its for the reliability of it, but ive read up that bike engines arent that reliable? but i dont know where to start, lowerest budget possible
Posted 21 April 2013 - 03:33 PM
Trying to build a bike engine mini on the cheap? i wouldn't even bother.
Posted 21 April 2013 - 04:46 PM
i know lol, what should i do? where do i start lol
Posted 21 April 2013 - 05:22 PM
Just need an engine/box/pedal box/gear linkages i think??
Edited by Andy!, 21 April 2013 - 05:22 PM.
Posted 21 April 2013 - 08:26 PM
Just look at all the build threads past and present and you can see how much goes into them.
I would have around £7000+ set aside if you're buying mostly off the self parts as alongside a conversion kit you need to consider brakes, wiring loom, suspension, fueling, exhaust system, dash display etc
The cost can get out of hand quite quickly.
Posted 23 April 2013 - 03:06 AM
If you can fabricate your own subframe to hold the bike engine you could save money. If not you will need to go to someone like pro-motive.
I think from the sounds of it he won't be fabricating much of anything. No shame in it though. I'm not much of a welder myself....yet
However, that is a fair assessment price wise and probably a little cheap if you are going with a pro-motive swap with all the goodies. And honestly a VTEC swap isn't going to save you much more off of that so if you are in it to spend the least amount of money possible, maybe a conversion isn't for you.
Don't let this get you down though! I had the exact same intentions. Even worse, I started hacking my mini with the grand illusion that there was no other way it was happening. Since then I have refined my ultimate plan and I think i'll be looking at a larger bore A series engine for the time being. Maybe graduate to a conversion
Posted 23 April 2013 - 05:01 AM
http://www.ebay.co.u...984.m1423.l2649
Edited by creakyjaws5533, 23 April 2013 - 05:01 AM.
