2 Degrees Toe In On Rear - Too Much?
8 replies to this topic
#1 miniman24
miniman24
  • 1,696 posts
Posted 19 April 2013 - 04:20 PM
Hey all, Ive just had my rear toe measured, and its at 2 degrees toe in, as measured on the old Dunlop style gauges. This is right at the end of what the gauge can measure, so I assume this is too much? The garage that measured it said you cant convert it to mm, but I wasnt convinced, so are they right?
#2 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 April 2013 - 04:33 PM
I am not entirely sure - but i think it is 0.2256 degrees for each mm toe
#3 miniman24
miniman24
  • 1,696 posts
Posted 19 April 2013 - 05:31 PM
Any more opinions on this?
#4 carbon
carbon
  • 2,590 posts
Posted 19 April 2013 - 06:10 PM
2 degrees is a lot of rear toe-in.
A BL factory manual from early 70's mentions 1/8 inch (ie 3.2mm) toe-in. If the above 0.2256 deg per mm is correct then the factory manual setting would be equivalent to about 0.72 degrees toe-in.
Have you checked the alignment on both sides?
#5 miniman24
miniman24
  • 1,696 posts
Posted 19 April 2013 - 06:15 PM
Its just about equal toe in either side - it is a pattern subframe, so Im guessing this is the cause :lol: Im going to get some of these shims
http://www.minispare...assic/CK17.aspx
to correct it, they add 0.7mm toe out each.
#6 Cooperman
  • 23,285 posts
Posted 19 April 2013 - 06:45 PM
The correct toe-in is 1/8". This represents 1/16" over a 12" diameter each side. So, dividing Opposite by Adjacent we get 0.0625/12 = .0052. This is the tangent of the angle of one wheel which is 0 degrees 18 minutes. So the combined angle across the back wheels is 0 degrees 36 minutes, or just over 0.5 degrees, this being the maximum figure.
#7 miniman24
miniman24
  • 1,696 posts
Posted 19 April 2013 - 07:01 PM
Thanks for that Cooperman, just the info I needed - I have 10" wheels, which gives a value of 0.00625 when applying the Tangent function rather than the 0.0052 for the 12" wheels - what would this be in degrees and minutes? Or does this not apply and the 0.0052 value works for all wheel sizes? If so, using the values, I need 5 shims each side to bring the toe into spec.
#8 Cooperman
  • 23,285 posts
Posted 19 April 2013 - 08:13 PM
0.00625 as a tangent is 0 degrees 24 minutes, so the maximum toe-in should be 48 minutes which is 0.8 degrees inclusive across both wheels. I'm sure I don't need to mention it, but make sure the car is equal both sides with respect to the front suspension.
#9 miniman24
miniman24
  • 1,696 posts
Posted 19 April 2013 - 08:32 PM
So I need to take away 72 minutes of toe in to reach the max acceptable value - which equals approximately 8 shims. A fair way out! I will double check the wheel bases front to back and diagonally, but the body is mint with a bare minimum of welding ever carried out, so hopefully it should not be out by much. Thanks very much for your help :)
