How To Undo This Bolt?
9 replies to this topic
#1 Lukie-J
Lukie-J
  • 858 posts
  • Local Club: South Devon Mini Club
Posted 19 April 2013 - 08:30 PM
Not mini related which is why it's in GenChat but thought someone might have a good idea!
Got a bolt like this: http://i01.i.aliimg...._head_bolts.jpg
It's in a children's climbing frame of all places and has a lock nut which is slightly rusted.
The square hole where the head of the bolt sits is in plastic and has rounded off, tried some long-handle angled grips on the round end but when I turn the nut it just slips out of the grips. As you can imagine there's not much to grip onto.
Anyone got any suggestions about how to get it out?
Cheers!
They look like this...
Edited by Lukie-J, 19 April 2013 - 08:35 PM.
#2 TylerW53
TylerW53
  • Just Joined
  • 104 posts
Posted 19 April 2013 - 08:32 PM
Lots of WD40 and mole grips done up tight?
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
cut a flat into head and hold with screw driver.
either that or cut it off completely.
#4 Lukie-J
Lukie-J
  • 858 posts
Posted 19 April 2013 - 08:37 PM
Trouble is, the climbing frame needs to be sold so can't just cut it unfortunately. I'll borrow some mole grips but don't think I'll be able to get a grip on it. Hmmm....
#5 Alex_B
Alex_B
  • 4,573 posts
Posted 19 April 2013 - 08:39 PM
looks just like a standard flat headed coachbolt, similar used in vintage mgs and similar for holding on the bumpers, so cut a flat into it and buy a new bolt?
#6 dow62
dow62
  • 355 posts
Posted 19 April 2013 - 08:48 PM
Split the nut with a grinding/cutting bit, in a dremmel ( type ) tool
#7 Lukie-J
Lukie-J
  • 858 posts
Posted 19 April 2013 - 08:53 PM
I think I'll cut it off then, thought there might be some trick to it but looks like I'll be taking a trip to wickes!
#8 analogue_radio
analogue_radio
  • 4,897 posts
Posted 19 April 2013 - 08:58 PM
These are heaven sent - Irwin 5 Piece Bolt Grip Nut Remover Set.
#9 jmmini
jmmini
  • 711 posts
Posted 19 April 2013 - 09:22 PM
Yes, just cut a small groove on the smooth side and use a flat-head screwdriver, and longish socket or spanner to crack it off
#10 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 19 April 2013 - 09:40 PM
break the nut in 2 and buy a replacement nut
