Could I run my fuel pump of a toggle switch? And also remove the inertia switch? It's a mpi set up.
Fuel Pump Switch?
o0OWILKSO0o
, Apr 21 2013 11:42 AM
5 replies to this topic
Posted 21 April 2013 - 11:42 AM
Posted 21 April 2013 - 11:58 AM
Don't remove the inertia switch, its a safety item in the event of a crash.
You can run it on a toggle switch though, I just wired a toggle switch into the fuel pump wire between the pump and inertia switch.
Posted 21 April 2013 - 11:59 AM
yes if you remember to switch it off just before an accident
you wouldn't want to be stuck in the car with fuel pumping out every where
Posted 21 April 2013 - 12:11 PM
Ok keep intertia and run an inline switch. That's a job for next week.
Posted 21 April 2013 - 06:36 PM
On rally cars the inertia switch has to be removed or by-passed. If this is not done the car cuts out every time it goes over a big bump - which is quite often on a rally.
Posted 21 April 2013 - 09:08 PM
do you use a relay and take the trigger off the oil pressure switch to maintain a safety switch ?
