Problem Fitting Minispares 7.5" Discs Kit
19 replies to this topic
#1 Markpash1980
Markpash1980
    Just On Tickover
  • 6 posts
Posted 21 April 2013 - 01:20 PM
I have bought the minispares 10" wheel brake kit which allows me to replace my current 8.4" brake and caliper set up with a new 7.5" set up. However when i removed the old disc and flange and tried to fit my new disc and flange the disc is getiing stuck as there is a clearance issue between the inside of the disc and the hub. Has anyone else had this problem?
It looks like there should have been more machining of the disc inside but both 7.5" discs are the same. Also the drive flange and rear of the disc is deeper on the 7.5 set up than the 8.4 so the disc is pushing up against the hub and binding. There isnt something right at all here. Can anyone help?
#2 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 21 April 2013 - 01:23 PM
Have you called MiniSpares.......?
#3 Markpash1980
Markpash1980
    Just On Tickover
  • 6 posts
Posted 21 April 2013 - 01:28 PM
I have tried to fit them this morning. There closed today to call them.
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 21 April 2013 - 01:39 PM
The outside edge of the hub was machined differently originally when it was used with 7.5" discs than when used later for the 8.4" setup. Although it is the same casting, the machining detail was slightly different right at the edge. Is used to be machined into a step leaving quite thin material which was fine because that area is only supporting the seal and not the bearing. In the interest of cheapness this detail was deleted when the 8'4" discs were brought in because there is far more clearance inside. This is an issue with some specific 7.5" discs, but not all of them. It's due to tolerances stacking up that some discs will touch but most won't. Simply swapping the discs should solve it.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 21 April 2013 - 01:42 PM
Although it should just be the disc rubbing. If as you say above the flange is rubbing too then something is assembled wrong.
#6 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 21 April 2013 - 01:43 PM
I think i've seen this before, there may be a fault with the casting. I'll try and find the thread.
#7 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 21 April 2013 - 01:44 PM
http://www.theminifo..._hl__minispares
Is this the same problem?
#8 Markpash1980
Markpash1980
    Just On Tickover
  • 6 posts
Posted 21 April 2013 - 01:48 PM
The flange is fine. I was saying when the flange was screwed to the disk and fitted this is when the binding happens to the disk.
#9 Markpash1980
Markpash1980
    Just On Tickover
  • 6 posts
Posted 21 April 2013 - 01:59 PM
That isnt the same problem. I havnt even got to fitting the calipers. The disk is binding against the hub
#10 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 21 April 2013 - 02:03 PM
The front overall shape and front edge of a genuine original S hub is different to the more common 8.4" hub.
Normally there is no problem swapping between the two, but sometimes the inside cast finish of the disc fouls the outer edge of the step on the hub.
It is probably the fault of the hub and not the disc.
Talk to Mini Spares on Monday and see if they will swap the disc - however, it is still possible that you will have the same issue with a different disc.
#11 Markpash1980
Markpash1980
    Just On Tickover
  • 6 posts
Posted 21 April 2013 - 05:25 PM
Thanks everyone ill let you know how it goes
#12 Markpash1980
Markpash1980
    Just On Tickover
  • 6 posts
Posted 22 April 2013 - 08:50 AM
Spoke to my local mini garage and they have had the same issue with that kit. They say the only option is to use new hubs. Which means i have to fork out for new hubs now.
#13 richw911
richw911
  • 2,084 posts
Posted 22 April 2013 - 09:10 AM
Did you speak to minispares?
#14 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 29 December 2013 - 11:54 PM
Sorry to bump an old thread. Just searching to see if anything on whether to get the brake kit with AP calipers, or MS calipers, but come across a few threads about some problems with the fitting using the MS calipers. Is this issue sorted now?
Edited by megamini_jb, 29 December 2013 - 11:55 PM.
#15 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 30 December 2013 - 08:37 AM
Best bet is to PM simon@minispares on here. He will be the best one to give up to date info.
