Overpainting Hammerite
7 replies to this topic
#1 Old Bob
Old Bob
    TMF Menber Passed On R.I,P
  • 825 posts
Posted 22 April 2013 - 10:29 AM
I know it's great stuff on bare metal but reacts with almost anything else which is already there - even really old stuff. However; can anyone comment on overpainting Hammerite with cellulose?
You could save me making extra work for myself!
Bob
#2 Mini_Alex
Mini_Alex
  • 175 posts
  • Local Club: East Devon Mini Club
Posted 22 April 2013 - 11:08 AM
If you use some sort of Barcoat (barrier) primer you should be able to. Its not recommended to paint over Hammerite but it may be worth a try.
#3 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 22 April 2013 - 11:21 AM
use barcoat first... or take it back to bare metal then prime and repaint
#4 Old Bob
Old Bob
  • 825 posts
Posted 22 April 2013 - 11:32 AM
Thanks Guys.
Bob
#5 Sam
Sam
    Wish i was in T.O.W.I.E
  • 2,323 posts
Posted 22 April 2013 - 12:06 PM
Tried spraying U-pol Gravitex over hammerite. Not sure if Gravitex is celly, but it reacted awfully and massively delayed my project.
I'd avoid hammerite on any parts of bodywork / floors - apart from the reactions, it's not great on cars as it is brittle and cracks when the panels flex
#6 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 22 April 2013 - 12:42 PM
I was advised its ok to use as long as its left long enough for the oils, thinners etc to evaporate. I'm talking about at least a month, but this could change with different temps and humidity. I've use hammerite on the inside of my boot which will end up getting panelled so not so much of a problem in my eyes. I've also just primed the inside and underside will an oil based primer as it'll be a good while before I stonechip it so I'm hoping things work out! If there's still a reaction then a barrier coat will have to be applied.
#7 jaydee
jaydee
  • 8,565 posts
Posted 22 April 2013 - 01:05 PM
Hammerite will be a bit time consuming to sand it back, i've painted over hammerite using a barcoat primer, no problem at all
#8 skoughi
skoughi
  • 1,199 posts
Posted 22 April 2013 - 04:22 PM
Yeah its tough stuff! I had to sand back some as a little rust had started again and it needed it all to get it feathed out. I sprayed on some etch primer and what landed on the hammerite didn't react. But the hammerite had been on for a good while.
