1968 998 Cooper Engine
#16
Posted 23 April 2013 - 08:22 PM
#17
Posted 23 April 2013 - 09:24 PM
Can "d top" pistons be used with a 12g940 head?
i would imagine that the d-tops with the 12g940 woould make your compression ratio too high as the 940 has a combustion chamber that is much smaller than on the 295
also with raised pistons you may well get valves hitting the pistons with the 940 head
#18
Posted 23 April 2013 - 09:49 PM
#19
Posted 24 April 2013 - 12:50 AM
#20
Posted 24 April 2013 - 06:00 AM
#21
Posted 24 April 2013 - 09:23 AM
#22
Posted 24 April 2013 - 10:32 AM
#23
Posted 24 April 2013 - 12:42 PM
Power band will sit pretty high in the rev range though
#24
Posted 24 April 2013 - 02:44 PM
Edited by Cooperman, 24 April 2013 - 02:44 PM.
#25
Posted 24 April 2013 - 03:03 PM
1130cc ( 1098 +40 )
12g295 ( shaved to 24cc chambers......080" )
SW5
twin 1.125" ( sometimes I run an HIF38 with AAU )
LCB
rc40 equiv.
Now...as it's a long stroke engine I'm not going to be running at 6k + very often so may be hard to compare with a 998 running at 6600.
( I did install a better piston that doesn't have the ring below the pin )
#26
Posted 24 April 2013 - 03:10 PM
#27
Posted 24 April 2013 - 03:38 PM
#28
Posted 24 April 2013 - 03:44 PM
A 1098 will give good low-end torque, but to get a lot of power is difficult because of the rev limitation on the crank.
The problem with any modified engine is that the power/torque band becomes narrower and higher in terms of revs. Unless, of course, you go to forced induction.
#29
Posted 24 April 2013 - 07:02 PM
Want to have to rev to get my power if that makes any sense I want it to be a revy little engine and there's no point with a 1275 as that would bore me I'd rather have a racy 998 that goes as fast as a 1275 than a standered 1275
#30
Posted 24 April 2013 - 07:03 PM
