Painting A Mini With An Earlex Hv3000 Vs Using A Compressor?
4 replies to this topic
#1 crazicarl
crazicarl
  • Just Joined
  • 64 posts
Posted 25 April 2013 - 10:41 AM
I have never sprayed a car before and am learning lots about prepping and various other things to take into consideration when painting a car.
My question, is it possible to spray a mini with an Earlex HV3000 or would you recommend trying to get a compressor witth an oil and water trap?
I am trying to watch my finances at the moment and can't really afford to shell out for a decent and suitable compressor that's up for spraying cars as well as all the extras that you would need to do so.
Any help and advise would be greatly appreciated, thanks.
#2 kappa
kappa
  • 1,301 posts
Posted 25 April 2013 - 10:42 AM
I would recommend a compressor, but I may be wrong
#3 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 25 April 2013 - 10:50 AM
the earlex HV3000 is prone to blocked jets... compressor is the way to go... change the oil on the compressor and drain it of water.. you can hire a compressor and airlines from a few company's.
#4 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 25 April 2013 - 04:39 PM
I'm going to be having a go with one before too long.
You could do with a decent filter system if you're going to use a compressor.
#5 nrwilliams
nrwilliams
  • 133 posts
Posted 26 April 2013 - 02:08 PM
I have painted a number of things with an Earlex spray station including two cars with cellulose, I found it ok. What I liked about it was the lack of masses of overspray, I did not cover the neighbours cars with paint and also its quiet. I have used a compressor before and it was a small one but it was very noisy as it was running a lot to keep up.
