Spec is:
Russes engineering re013 cam. Similar to kent 286
Swift tune head with 37mm inlets 29 exhaust
Maniflow LCD to rc40 twin box
Twin hs4 with AAB needles with k&n cone filters
Std rockers
Calver modded distributor max advance 28 deg
Since running it in, about 500 miles, then engine in strong throughout the mid range but when it hits 5500 rpm it's like a rev limiter cuts in.
I checked the timing and am getting 28deg NTSC at 4500 rpm
Switch the engine off and removed a plug which looks like its running a tad lean
edit:
DSCF6688.JPG 50.41K
5 downloads Looking at this photo blown up I we deffo say thats a bit week!If its running lean would I get this symptom?
Calver originally suggested AAM needles but they are weeker at the top end according to Minty's site so what needles should I try next and is there anything else I should check?
Edited by Petro1head, 25 April 2013 - 05:54 PM.
