Swirl Marks
8 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 25 April 2013 - 08:04 PM
Hi all i have a wing with a few swirl marks on it
can anyone let me know how to get rid of them please
#2 fattail95
fattail95
  • 873 posts
Posted 25 April 2013 - 08:06 PM
It depends on the severity of the scratches, if they are really bad use a cutting compound, followed by a finishing polish. Bear in mind that something like AutoGlym SRP will fill the scratches, giving the illusion that they are no longer there. However, that is not a permanent fix so do it properly the first time IMO. Finish with a good quality wax/sealant and youre good to go!
#3 087dave
087dave
  • 952 posts
Posted 25 April 2013 - 08:30 PM
Tks what about using a cutting compound then some t cut??
#4 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 26 April 2013 - 10:09 AM
T-cut is a very mild polish (reads crap).
Think of it in 4 rough stages(Omitting the cleaning or paint prep);
1) Compound - This stuff is a liquid containing abrasive particles, a bit like liquid sandpaper. The particles are large and so they 'cut' quickly but deeply into the paint or clearcoat so by applying even pressure you get consistent level across the surface.
2) Polish - Similar to compound but smaller particles, the cut is less pronounced so takes a little longer but like finer sandpaper creates a more level finish
3) Glaze - This is what most people think of when they say polish, it's a waxy or oily formula designed to make your paintwork look amazing, shiny and wet. They're rarely abrasive at all but some have filling qualities for tiny imperfections or when the paint depth is too thin to use an abrasive.
4) Wax or Sealant - Two options to protect your now lovely shiny finish from the elements and bird poo! :P
In reality the compounding / polishing stage is where your work is, for swirl marks left over from previous cleaning then polish (real polish) will probably do the job. But you need to put it on right and have the paint clean before you start.
Correct cleaning technique and detailing will fix the problem but if you're slapping Mr. Sheen on with an old T shirt you're fighting a losing battle :)
Edited by Skortchio, 26 April 2013 - 10:11 AM.
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 April 2013 - 10:17 AM
i have used "meguiars scratch x" with good results.
I used a DA though, it should be possible by hand. Use plenty of product on a micro fibre cloth, and give it good firm pressure. Apply the product any way you want, doesn't need to be circles.
finish with a good polish and wax.
#6 Scoop77
Scoop77
  • 508 posts
Posted 27 April 2013 - 06:59 PM
Will you be doing it by hand or do you have a MOP of some description?
#7 087dave
087dave
  • 952 posts
Posted 27 April 2013 - 07:16 PM
By hand
#8 Scoop77
Scoop77
  • 508 posts
Posted 28 April 2013 - 04:49 PM
Ok. Well to completely remove swirls and light scratches by hand isn't impossible but will be hard work. The meguires ultimate compound and polish are considered to be versions of their well known 105 and 205 and are very popular. I would suggest trying these on what are called German pads ( because of the colours ) If you have removed what you want then wax or seal. If you haven't then have a look at Poorboys Blackhole which is a glaze that has lots of fillers in and then your wax or sealant.
#9 richw911
richw911
  • 2,084 posts
Posted 28 April 2013 - 08:55 PM
Then bin your sponges!
