Electronic Ignition? What One Would You Suggest Is Best..
20 replies to this topic
#1 scotty_1987
scotty_1987
  • 874 posts
  • Local Club: MiniBallers
Posted 27 April 2013 - 11:52 PM
Hey all,
I know this has been posted a lot before i have the links but i'm just getting bogged down in which is actually best to go for? i have seen the landy one for £15!! that seems like a good option is there anything else you need to buy or is that it? and will that be beneficial on it's own to make my 998 a lot more reliable? cheers for any advice you have, and if you have any sub £50 electric ignition options you have send em my way!!
Nathan
#2 tractor
tractor
  • 662 posts
Posted 28 April 2013 - 06:48 AM
Defiantly worth installing electric ignition, my system is non balest and I run with accuspark,
Here's what I bout but I can't remember paying £30 for it thou...!!
http://www.ebay.co.u...=item484170caff
Trac
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 28 April 2013 - 07:00 AM
i'm very impressed with the maplins velman kit a few of my friends use
and for just over a tenner it's very good value
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 28 April 2013 - 08:16 AM
Another vote for accuspark. They now do the stealth one (crap name) with adaptive dwell for £30. Very good system with only two wires to connect. Then a quick retime with a strobe light and you are done.
Edited by Tamworthbay, 28 April 2013 - 08:17 AM.
#5 scotty_1987
scotty_1987
  • 874 posts
Posted 28 April 2013 - 09:55 AM
Ah ok cheers guys I'll go for that one so :D!!
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 28 April 2013 - 10:08 AM
http://www.mm-4x4.co...-kit-2721-p.asp
Without vat or post, same or more than the £25 accuspark one on eBay, without the adaptive dwell feature.
#7 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 28 April 2013 - 04:31 PM
To be fair the vast and delivery don't add up to twenty five quid, it works out at less than twenty quid........ All Accuspark have done is take a standard part and rebrand it, if you want to pay for the privilege of someone else sorting it for you fair enough sucker..........
Have you checked the postage? No, I contacted them on Friday and the postage is just under £6. With the 20% vat that makes close to £25 in my book, but if you want to let someone else add stuff up for up for you, fair enough........
Edited by Tamworthbay, 28 April 2013 - 05:27 PM.
#8 scotty_1987
scotty_1987
  • 874 posts
Posted 28 April 2013 - 06:27 PM
ah now lads let's not fight let's be friends  :highfive: !! but at the end of the day the accuspark is the one to go for yes?!
Cheers,
Nathan
#9 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 28 April 2013 - 06:32 PM
Cheers,
Nathan
I have them in three cars and they work very well indeed, the new stealth ones are the best yet. AND their customer service is superb. As for Dilligaf, he just doesn't like to play nice, don't worry about what he says, no-one else does!
#10 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,073 posts
  • Name: Neil
Posted 28 April 2013 - 06:57 PM
Right enough of the sarcastic and belittling comments. If this carries on then warnings will be issued. This will not turn into another slagging match.
#11 lrostoke
lrostoke
  • 6,923 posts
Posted 28 April 2013 - 07:38 PM
The Britpart used to be less than £7 a couple of years ago :(
Couple of quid cheaper from Paddocks though
http://www.paddocksp...tronic-kit.html
#12 scotty_1987
scotty_1987
  • 874 posts
Posted 28 April 2013 - 07:53 PM
Cheers,
Nathan
Coolio :D!! Will do
#13 scotty_1987
scotty_1987
  • 874 posts
Posted 10 June 2013 - 07:01 PM
Reviving my own thread here but it's easier than starting a new thread so i'll just ask here will the following product fit my 998cc 1985 Mini Mayfair? And does anyone else have these parts fitted as i'm unsure or not as which to go for this or the above products!!
Cheers Nathan
http://www.ebay.co.u...=item27d30e8b79
#14 lrostoke
lrostoke
  • 6,923 posts
Posted 10 June 2013 - 07:13 PM
The link you've posted will work.
Guess the question is do you need all the new components ?
If you were planning on replacing the whole lot then fair enough.
But if coil , plugs and HT leads are all in good condition then no need for the lot.
#15 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 10 June 2013 - 07:34 PM
i bought mine from an ORCi ministox, used with coil and all wiring for £45. just have a look on ebay :)
