Hi,
I've just wire brushed, undercoated and hammerited my sub-frame. when I put it on the car should I build it up first and then waxoyl it, or waxoyl it all within an inch of it's life before building it up?
Ta
RodAndTom
Posted 28 April 2013 - 02:29 PM
Hi,
Ta
RodAndTom
Posted 28 April 2013 - 02:32 PM
I'm going to Waxoyl once built up. It's horrible stuff to handle especially when building up. Lots of aerosols of the stuff etc.
Posted 28 April 2013 - 02:48 PM
Waxoyl in the holes and top then do the rest when in would be easier and less messy
Posted 28 April 2013 - 02:52 PM
Posted 28 April 2013 - 08:56 PM
Can Dynax S50 be used everywhere Waxoyl would normally be used then?
Posted 28 April 2013 - 08:59 PM
Posted 29 April 2013 - 10:14 AM
+1 on the Bilt and Hamber Products. Their products are excellent.
I've just done Project 45 with the Dynax S50 in the cavities and the Dynax UB for under the arches and underneath. They even do a clear wax (Dynax UC) for any visible areas that you may want to do.
The cans with the lances are fantasic for the cavities i.e. the Dynax S50 with the lance.
I used a Schulzt gun loaded with the Dynax UB for underneath, the subframes and the arches. Made the job a whole lot easier and quicker plus a hell of a-lot neater.
Posted 30 April 2013 - 09:35 PM
Posted 02 May 2013 - 11:21 PM
+2 with the Dynax
Posted 03 May 2013 - 10:59 AM
Interesting!
http://www.classicsm...-waxes-on-test/
But then there is this.
http://www.ppcco.com.au/dynax3.htm
Looking at the Classics monthly tests there doesn't seem to be any of the S50 actually on the metal! Anywhere that I've done with it is literally covered and a very noticeable black/dark brown in colour.
Posted 03 May 2013 - 12:16 PM
Posted 03 May 2013 - 12:27 PM
I use the Bilthamber Dynax stuff as well, filled the inside of my sills with it, a year later looked inside and it was still the same consistency as the day it went on, impressed with that. There underbody stuff is great aswell, a pig too get off though, but guess thats kinda the point!
Anyone tried the clear one?
Posted 03 May 2013 - 01:43 PM
It looks like a case of "you pay your money and make your choice" how ever I like the idea of using a really thin one to penetrate seams well then covering up with a thicker one later. and remember don't just heat up the can of coating (whichever one you decide upon) but heat up the metal too to improve penetration!
So are you saying that after I have primed, undercoated, topcoated, then hammerite, then waxoyl or dynax s50 - I should warm up the seams to allow protection to seep through? Wont that buble the paint and let corrosion occur?
RodAndTom
Posted 03 May 2013 - 06:44 PM
Posted 04 May 2013 - 07:25 AM
I get it and it does make sense. I shall do that.
Good call
RodAndTom
