Underlay Question
9 replies to this topic
#1 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 29 April 2013 - 07:17 PM
When I stripped the interior out of the car, there was a large moulded rubber backed foam underlay that was seated in the front footwell and Up the bulkhead behind the pedals. My dad is adement this was a "fire retardant" underlay matting of some sort. Can anyone help me? I can find it anywhere, or anything similar?
#2 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 29 April 2013 - 07:28 PM
Isnt it just the sound proofing? mixed with glue? not sure though...
#3 A-Cell
A-Cell
  • 1,610 posts
Posted 29 April 2013 - 07:37 PM
It is sound deadening. It's heavy rubber backing with a "chip foam" layer. Very effective panel deadened and sound barrier. If you want quiet then put it back. In no way is it fire retardant.
#4 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 29 April 2013 - 10:46 PM
This was my understanding. Unfortunately it was rotten and ruined so it was chucked. Can you buy them anywhere?
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 April 2013 - 10:47 PM
  Original trim like this is almost impossible to find.  Try Somerford, they might have some.  If not there are other underlay kits available but they don't have the heavy rubber backing.
#6 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 29 April 2013 - 10:50 PM
Thanks Dan, I've got the newton commercial carpet and underlay set, but it's no where near as thick, and as you said, without the rubber backing. Many thanks.
#7 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 30 April 2013 - 06:42 AM
So what do people use if they cant get this stuff?
#8 Wakey-Dan
Wakey-Dan
  • 256 posts
Posted 30 April 2013 - 07:41 AM
Try classicminbits.co.uk he strips minis for spares and second hand will be your best bet. Othewise have a look on ebay for some dynomat (expensive) or silentcoat (budget)
#9 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 01 May 2013 - 09:22 AM
I've bought some closed cell foam underlay/mat that I have put in the back. Just think the moulded rubber backed bit would be good in the front.
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 May 2013 - 11:35 AM
  All it really does is hold water against the floor and bulkhead causing rust, which closed cell foam won't do.  It's easier to fit because it's moulded but it's also very heavy.  The reason it stops sound is that it has the density change where the heavy rubber is bonded to the light rubber, it fits tightly and covers all the holes and overlaps the seams.  You could easily do a similar thing by bonding some heavier rubber sheet to the closed cell foam.  Or go to Noisekiller's website and look at their bulk materials rather than kits.  They have a wide variety of this sort of sandwich material available.
