Brake Disc Acceptable 'run Out'
1 reply to this topic
#1 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 30 April 2013 - 06:29 AM
I have an annoying feel on the brake pedal and one disc goes tight and loose as I revolve it so something is out.New discs 1000 miles ago,and I should add I rarely use the brakes!! never once in anger really,defo not been hot. I checked the disc in a lathe and with the mounting surface running true, the max run out at extreme edge of disc is 2 thou. I need to know if this is acceptable or if I should return/replace it. Didnt seem much and today I'm going to check the drive flange to see if it's that which is causing the problem.
#2 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 30 April 2013 - 08:42 PM
Doesnt matter now, but thanks for the 29 views. I mounted the drive flange in the lathe and machined the faces then bolted the disc to it and machined the disc so it had to be running true like that.....sorted !
