Brakes - Car Pulling To One Side
No replies to this topic
#1 Petro1head
Petro1head
  • 168 posts
  • Local Club: Cooper Register north est
Posted 30 April 2013 - 07:36 AM
have 7.5" S Disk setup with Mintex 1144
Under heavy breaking the car tends to steer to the right suggesting I may have a problem with the LHS calliper.
I checked it over the other week, removed the outer pad and pressed the pedal to push the piston out which took more force than I would expect. (inner was fine)  So I gave it a liberal coating of WD40 and then pushed it back in, repeated this several times and by the time I was finished it took little pedal force to push the piston out.  Jobs a goodun I thought.
Took the car out last night to check and its still pulling to the left under heavy breaking :(
Just to add, all ball joints been done, new tie bars and rubbers, to and bottom arm bushes all good, shockers are new and tyres had 28psi each side.
So I can only assume I have not done enough to free off the sticky piston.  So I am now thinking about removing the calliper, splitting and taking the piston out and making sure all is clean and ok.
Any thoughts about anything else I should be aware of and pitfalls to stripping the calliper gratefully accepted :)
