Mini Detectives, Cylinder Head Identification
11 replies to this topic
#1 marsy
marsy
  • 374 posts
Posted 02 May 2013 - 05:48 PM
I asked this a while back, but have now cleaned the head up and noted numbers by thermostat which are 12G 1805 what does that mean?
Thanks Attached File  IMAG0754.jpg   43.45K   25 downloads
#2 marsy
marsy
  • 374 posts
Oh noted its got double valve springs too.
#3 Tupers
Tupers
  • 4,173 posts
Posted 02 May 2013 - 06:22 PM
MK1 Cooper S head.
#4 A-Cell
A-Cell
  • 1,610 posts
Posted 02 May 2013 - 07:09 PM
Casting is probably 12G940, if the valve sizes are 35mm inlet and 29mm exhaust and it has 11 stud holes then it is a 1275 Cooper S head.
#5 marsy
marsy
  • 374 posts
Posted 02 May 2013 - 07:44 PM
Yup casting is 12G940 mowog I measured the valve sizes roughly and they seem to be 30mm and 35mm, so could be 29 and 35? As used a tape measure so not accurate.
Which holes do i count to see if it's 11 stud head? Thanks
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 02 May 2013 - 08:06 PM
  It is, you can see on the photo.
#7 mini13
mini13
  • 3,811 posts
Posted 02 May 2013 - 08:08 PM
late cooper S head, has the cooper S rockers too,
looks like it may have been ported a bit too.
#8 marsy
marsy
  • 374 posts
Posted 02 May 2013 - 08:20 PM
Cool, so what sort of extra performance would you get from this head, compared to standard?
#9 Cooperman
  • 23,513 posts
Posted 02 May 2013 - 08:25 PM
If you get the compression ratio correct at about 10:1 you could gain a few bhp. Of course, you will also need to improve the carburation and exhaust system if you haven't already done so.
#10 marsy
marsy
  • 374 posts
Posted 02 May 2013 - 08:45 PM
Compression ratio? How's that done then? (Sorry)
And have twin carbs, and looking at getting a straight through rc40 exhaust
#11 marsy
marsy
  • 374 posts
Posted 02 May 2013 - 08:46 PM
Would this head go straight onto an ordinary 1275 block? Or is there modifications needed?
#12 Cooperman
  • 23,513 posts
Posted 02 May 2013 - 09:01 PM
It depends on what the compression ratio would be. There are so many different types of piston used over the years that measurement & calculation are vital. It's no good fitting a better head if you end up with, say, 8:1 compression ratio as it will simply just be slower.
The basic advice is to understand what you are trying to do and why before starting to do it.
The Cooper 'S' head is also drilled to take 11-studs, whilst the basic 1275 block is drilled for only 9.
