Pre A Plus Engine Breathing
Posted 03 May 2013 - 01:46 AM
Currently I only have a breather on the transfer housing. It here a timing cover with breather that will fit? If there is, i haven't found it. Or is my only option to add a breather at the fuel pump takeoff or rocker cover?
Thanks,
Keith
Posted 03 May 2013 - 02:07 AM
Some A's also used the same tensioner as the A+. both the early egg shaped 'n later chain cover were available with a breather can. You should be able to fit a later cover over an earlier rubber ring tensioned chain, but you might have to drill an extra hole in the end plate, or swap that too. The breather cans on Metro engines need a bit of hammer shaped tlc to clear a Mini's fan. Another option is to stick a pipe on the engine side of the end plate, near the fuel pump, like you can find on inline A Series.
Posted 03 May 2013 - 02:34 AM
Posted 03 May 2013 - 05:42 AM
I fitted the later A+ type cover with breather to my A-series engine. I had the engine apart so changed the back plate behind the chain too, but i dont think you need to. Just the cover and its gasket.
I got mine from minisport at the time.
Posted 03 May 2013 - 10:12 AM
