Heater Hoses, Which Size?
Posted 03 May 2013 - 08:00 PM
Just bought a silicone hose kit (1/2 diameter) but not sure its going to fit. My mini spi 94 has got the latest heater matrix with the hose taps on the left pointing up, and i think these taps are for 5/8 diameter hoses.
My heater valve is fixed to the head on the drivers side. Which i think takes 1/2 hose??
My question is, is the above all wrong, can i fit 1/2 hoses onto 5/8 tap safely? Or do i need to get the 5/8 hoses?
Any help GREATLY appreciated.
Posted 03 May 2013 - 08:28 PM
Your heater is 5/8", but if you have the head mounted heater valve that is the old 1/2" one. You shouldn't force the hoses on to the larger spigots. Presumably there is a hose adaptor somewhere between the valve and the matrix, you would need 1/2" hose between the valve and the adaptor but the rest should be 5/8". The bottom hose connection is usually 1'2" with a size adaptor to 5/8" and it was like this as standard.
Posted 03 May 2013 - 08:41 PM
Posted 03 May 2013 - 08:42 PM
I did think this earlier but sounded a bit botch in my own head, was gonna hide the hose adapters cabin side, so the engine side looks better!
Has anyone done this?
Posted 03 May 2013 - 08:47 PM
Posted 03 May 2013 - 08:51 PM
Posted 03 May 2013 - 08:56 PM
Nothings straightforward with minis. Gotta love'em!!!
Posted 03 May 2013 - 09:11 PM
The later minis have a hose each side, so it is a bit trickier to mix and match!
Posted 03 May 2013 - 11:24 PM
They aren't exactly normal grommets. The hole in the bulkhead is a large oval and the grommet is kind of like a bellows. You will be best keeping the 5/8" hoes running through them.
Posted 03 May 2013 - 11:42 PM
I've seen people recommend just using 1/2 throughout and then heating in boiling soapy water to fit the matrix, but that sounds like a flooded footwell waiting to happen.
Just a thought though, your matrix may have screw in outlets so you may be able to replace with 1/2" units and run 1/2" throughout. But I would then worry about capacity.
Ian
