Fitting A Cometic Head Gasket
2 replies to this topic
#1 REDICE
REDICE
  • 99 posts
Posted 04 May 2013 - 02:31 AM
I have recently purchased a Cometic head gasket. Is there anything special that needs to be done ie machining block or head when fitting these multi layered gaskets, or do you fit them like any other?
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 04 May 2013 - 09:28 AM
Not know what application the engine is ? Is there a reason why you bought a Comteic gasket over the proven Payen for the A Series ?
If you do a search here you will see others who have used different types of gaskets other than payen and have head gasket issues and had to re do the job again.
Edited by KernowCooper, 04 May 2013 - 09:29 AM.
#3 mini13
mini13
  • 3,811 posts
Posted 04 May 2013 - 11:17 AM
with the steel layered gaskets you should have a nice smooth head and block surface, preferably surface ground.
