Best Way To Remove Tape Goo From Sun Visors
12 replies to this topic
#1 willava182
willava182
  • 704 posts
Posted 05 May 2013 - 07:46 PM
the previous owner put double sided tape on the sun visors... for no reason as far as i can tell.
and ive tred getting it off, and the residue / goo is still there.
any way i can get rid of it from stuff at home?
would they be alright in the washing machine?
there rover 93 visors, plasticy kind
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 05 May 2013 - 07:51 PM
Water will not remove it. Have you tried white spirit or meths???
#3 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 05 May 2013 - 07:52 PM
White spirit will be too aggresive.  Try WD40 or if you can get 'Sticky Stuff Remover' (actual name) its great! Lakeland usually sell it :)
#4 willava182
willava182
  • 704 posts
I haven't! but i will try it!
#5 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 05 May 2013 - 07:56 PM
Brake cleaner works! But be very careful and only use it in small amounts and very quickly!
#6 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 05 May 2013 - 08:01 PM
My dad uses Wurth industrial cleaner, works for most things...
#7 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 05 May 2013 - 08:02 PM
Now brake cleaner will be too aggressive, i would not have said the same for white spirit. FE10 will do it as it is a contact cleaner.
#8 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 05 May 2013 - 08:05 PM
We use this at work and its pretty amazing stuff.
http://uk.rs-online....movers/0491724/
#9 iwatkins
iwatkins
  • 381 posts
Posted 05 May 2013 - 08:06 PM
Anyone use a Zippo? Genuine Zippo lighter fluid is the best I've found for more delicate surfaces. For less delicate, just raw petrol works a treat. :-)
Ian
#10 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 05 May 2013 - 08:08 PM
Same company but this stuff, can't rate it enough. We use this on most things at work.
http://uk.rs-online....easers/4821255/
#11 willava182
willava182
  • 704 posts
Posted 05 May 2013 - 08:46 PM
Thanks for the suggestions! i just used WD40, i was too lazy to go to the shed hhaa,
But it worked very well!
#12 Mini 360
Mini 360
  • 4,933 posts
Posted 05 May 2013 - 09:32 PM
Glad to hear it!  Works wonders on everything haha! Just a wash over with wter to remove WD40 smell and slight residue :)
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 05 May 2013 - 09:35 PM
Light machine oil, GT85 or wd40 at a push, great for getting rid of sticky stuff, and a must have when sticking carpet down using spray contact adhesive.
