Hi I'm just wondering how much I should be expecting to pay for my cv joint to be supplied and replaced, I don't know if its the inner or outer so prices would be good for both if possible.
I'm sure it's the cv joint as when I'm on full lock to the right I get a knocking noise from the drivers side front wheel
Cv Joint Replacement Prices
smithy3793
, May 06 2013 07:13 PM
6 replies to this topic
Posted 06 May 2013 - 07:13 PM
Posted 06 May 2013 - 07:17 PM
labour £50 plus parts and might as well do drive shaft oil seal at same time and oil change.
dave
Posted 06 May 2013 - 07:18 PM
Hopefully that'll be nice and cheap need to get it done before himley so will be in first thing tomorrow I think :)
Posted 06 May 2013 - 08:01 PM
A garage would probably charge about 2-3 hours labour. Also add in the cost of new engine oil, as that will need draining in order to remove the driveshaft.
Posted 06 May 2013 - 09:21 PM
If parts come off easily enough, than it takes around an hour per cv joint to change. I managed to buy two outer cv joints for £33 each but prices vary.
Posted 06 May 2013 - 09:56 PM
do it in an hour no problem, no need to do the oil seal if it isn't leaking.
Posted 06 May 2013 - 10:00 PM
Oil seal is leaking so May as well sort it, two birds one stone
