I'd recommend the Kligersil Gaskets. Probably the best you can get for the thermostat housing.
http://www.moss-euro...teIndexID=18948
Oh and on the subject of thermostats I'd only run a 74c on a race engine as max power from an a series is generated around 70c. With a 74c thermostat in a road car the engine oil is not as likely to get up to a high enough temperature to boil of the contaminants i.e. water.
From the evidence that I have seen and speaking to the likes of Peter Vickers and AC Dodd the sweet spot for an Engine thermostat in the UK is 82c with the consensus to maybe swapping it to a 88c in the winter if you heater doesn't get hot enough!
http://www.carnut.co...blin/cool3.html
The 88c thermostat replaced the 82c thermostat in the UK in 1976 due to tightening emission regulations.
