So as is always the way; replacing one thing leads to replacing many things (I am aware that by replacing one moving part you make all the other older parts wear twice as quickly); So far I've replaced just the tie rods, (and fairly recently the dampers, doughnuts, trumpets and knuckles) but I'm probably going to go most of the way to replacing the whole front suspension.
My question is: As with the tie bars where poly bush on the outside and rubber on the inside is recommended due to shearing possibility; what is recommended for lower arms? Does this need one of each or are polyurethane bushes all round recommended?
Thanks again for the wisdom.
