I have a pre A+ engine that I’ve rebuilt. Problem is that although I’ve put 4.8 liters of oil in it the oil level barely touches the bottom of the dipstick (i.e. considerably below the Min mark). I’m wondering if I have an early/short dipstick that should be used without the plastic tube/extender. Could that be possible?
I’ve searched TMF and the consensus seems to be that pre A+ needs the plastic tube and a standard dipstick… and one post indicates the length of a standard dipstick is 11.5" from its collar to the very end of the stick. Mine is only 10" long. Taking into account that the plastic is 1.5" long then I guess if I removed that then the dipstick should read correctly. So…
- Is it OK to use this ‘short’ dipstick without a plastic tube (or will oil be more likely to blow past it)?, or
- Should I use the tube and get a new dipstick?
Cheers,
Colin.
Edited by colinu, 09 May 2013 - 04:33 PM.
