I´ve googled all day - but haven´t found this...
I´m trying to find a suitable dizzy (to start with) for my MG1100 engine that I will put in my Mini.
What I´ve been looking for is:
*When does maximum advance start, at what RPM - and what is it? 30 degrees? 32?
*What is the dynamic timing figure? (RPM+degrees)
*A complete curve would be jackpot
I just want to know where to start - cause I read somewhere that the 1100´s was special, dizzy-wise:
Unlike the 998, the 1100 is a little fussier on the ignition advance curve side of things / Keith Calver
Large-bore engines are less fussy about exacting ignition requirements than small-bores. The 1100-type being the most difficult to get right, with very particular requirements mid-range when tuned and worlds apart from large-bore curves. This should be remembered when swapping distributors from one engine to another. An 1100 dizzy in a 1275 will at run OK, but a 1275 in an 1100 can be courting disaster /Keith Calver
