Having decided to change to a non ballast system with the aftermarket
Ignition system by Powerspark, I felt it worth seeking confirmation of
my understanding of what’s involved.
Kernow cooper placed a good item under FAQ’s and it probably makes perfect sense when
You know what your doing, but I just want to be sure to avoid wrecking the module and
or ignition wiring. So here goes.
Replace coil with 12V version.
New 12v supply from ignition side of fuse box to + coil side.
Red module wire to + side of coil.
Black module wire to – side of coil.
Disconnect and tape up P/W & Y/W wires, set aside.
Adjust timing.
Hope this is correct.
