Hi all
Many of you will know my project car from these pages, and although I have not been on TMF much recently, I have been enjoying my mini.
The time has now come to build the 1275 engine that came as a spare when the car was bought, and has been sat in may garage in kit form ever since.
I know many ask about engine spec, and how much power etc (it'll make what it'll make) but what I am asking for is some honest advice from those with experience, to hopefully make a reliable, but fun engine.
The mini is not my only car, and although I use it sometimes to commute, I'm not reliant on it. It goes on the motorway from time to time but not for any extended period.
My driving style is quite relaxed. I enjoy a bit of speed in the right places and acceleration, but although my days of traffic light wheel spinning are long gone, it would be nice to "surprise" the odd boy racer.
So what do I have already?
- A series (not A+) full engine & gearbox which we suspect may have come from an Allegro.
- I have done a swap with Guess works for a 3.44 diff and have on order a full rebuild kit including a X pin diff
- I have a modified cylinder head with 29.2 ex and 36.6 inlets. The head started as a Minisport one but has been via the workshops of MED for additional work (chamber size not measured as yet)
- A Kent 286 cam - New and was at the right price
- I am running megajolt on the current engine
- I have a HIF44 carb and will use the standard airbox with K&N (don't want too noisy) Heated inlet manifold.
- Maniflow 1.75 LCB & Twin box
The plan
- Bore to +40 (1310?) using new P21253 piston set - idea being to retain some life in the block if needed
- Crank reground to next available size
- Std A series rods
- Convert to pre-verto clutch - Swap gear ring to suit pre engaged starter - Good / bad idea?
- Std (quality) oil pump
- Single (quality) cam chain set using offset dowels (as recommended by Carver)
- Source good condition std rocker set
I haven't a bottomless pit of money, but don't want to "spoil the ship" etc. It will of course visit a rolling road for set up once complete.
- Suggested CR?
- Best head gasket to use?
- Clutch recommendation (don't want heavy comp if I can get away without)?
- 286 cam - I have it already but could it be a mistake?
- Std or lightened (special) followers?
- Push rods - I don't have any at the moment?
- Centre main strap - opinions vary wildly?
- Lighten the flywheel a little?
- Full balance of crank etc?
I'm typing this thinking I must have missed the obvious, so feel free to point out. Any suggestions, comments observations on the above most welcome.
Thanks to all in advance
Let the discussion begin.................
Regards
Steve
Edit - forgot the exhaust ![]()
Edited by stevede, 09 May 2013 - 08:58 PM.
