Hey,
I have a 1989 Mini Thirty, it has recently had new Inlet Manifold Gaskets and tappet cover gaskets fitted by my local garage, it was then brought to my attention that the valve in the float chamber would require attention soon as it was starting to stick.
Whilst driving it back from the garage the car started coughing and spluttering along the road... I have now fitted a new float chamber lid which is adjusted to 3.3mm clearance. Once it was fitted it still didn't want to run so pulled a plug to see that it was running really rich and the plugs where covered in black soot.
I have then adjusted the mixture to get it running which I thought meant it was all over... Took the car for a run this morning and it was perfectly fine... just gone to pop to the shops and it will turn over and run for 10 seconds and then cough splutter and slowly die... pulled the plug and its caked in black soot again....
What would cause it to go from running perfectly fine to really rich without any adjustments being made? will it require a carb rebuild/new jet or could it be another fuel issue like the pump?
Cheers for any help
Tom
