Spi Auxillary Fan Switch Reusable After Radiator Replacement? [Solved]
7 replies to this topic
#1 l_bratch
l_bratch
  • 183 posts
Posted 12 May 2013 - 01:19 PM
Hi all
I'm about to replace the radiator on my 1995 Cooper Spi as it's corroded and leaking a lot.
I have the replacement ready to go in which has led me to discover that the auxillary fan switch exists.  Can I remove this from the old radiator and whatever seal/clip is used and re-use it in the new radiator, or do I need to buy replacements for the new one?
I thought it best to ask before removing the radiator so I don't risk being out of action while waiting for parts to arrive.
Luke
Edited by l_bratch, 22 July 2013 - 08:01 PM.
#2 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 12 May 2013 - 08:43 PM
If it is an original radiator replacement and the switch still works, reuse the switch. But to ensure no leakage I would replace these:
http://www.minispare...72.aspx|Back to
http://www.minispare...34.aspx|Back to
#3 l_bratch
l_bratch
  • 183 posts
Posted 13 May 2013 - 08:12 AM
Thank you, I'll get replacements for those before I begin.  I think the switch still works.
#4 l_bratch
l_bratch
  • 183 posts
Posted 21 July 2013 - 09:13 PM
I fitted this today with the new seal and retaining clip, but once it go up to temperature the radiator dumped all the water out through the the sender hole.
I tested it overnight before putting the new radiator in by filling it with water with the sender/seal/clip in place and it didn't leak at all, strangely.
Any idea what the correct way of sealing this hole is?
Luke
#5 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 21 July 2013 - 11:27 PM
As shown below in the Minispares picture. Installing the seal first and the sensor after is easier. Some WD-40 also helps. Make sure to rotate the locking clip to engage on the tabs.
http://www.minispare...02.aspx|Back to
Edited by xrocketengineer, 21 July 2013 - 11:27 PM.
#6 l_bratch
l_bratch
  • 183 posts
Posted 22 July 2013 - 07:29 AM
Hm, that is what is what I did.  I'll take the sensor/seal out again this evening to visually inspect.  Thank goodness I don't need to take out the radiator again to access it.
Edited by l_bratch, 22 July 2013 - 07:30 AM.
#7 l_bratch
l_bratch
  • 183 posts
Posted 22 July 2013 - 08:01 PM
Nice and easy to fix - the retaining clip had rotated (presumably while putting the rad back in) and the sensor came loose.  Wasn't easy to see last night!
Thanks for your help.
#8 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 22 July 2013 - 10:00 PM
Great to know that you got it sorted.
