Hi guys,
Had problems with removal of the flywheel for the last three weeks, after breaking 2 pulleys, 4 meters of studding, a bottle of propane, a hydraulic bottle jack and alot of effs i resorted to using the grinder All went well taking it carefully however when the clutch plate popped off several feet, scareing me stupid, it revealed i had taken a cm^2 x 3mm deep chunk out of the crank taper. With my dad saying 'yeahhhh go on son that will fine to use again' and my brain saying 'nooooo new crank time' i'm confused as to what to do.
it's such a shame as the engines only done 60k and is in perfect order. if i buy a second hand ebay crank is it a 'bolt on and go' solution, or will the crank journels/bearings have to machined? i'm reluctant to spent £250 on a brand new crank.
The engines a '88 998, completely standard, until now
thanks
Andy
