Hello all,
it's time to upgrade my Sealey 50 litre compressor, so have been looking around and came up with a couple of options, would appreciate your thoughts on these.
The prices below are inclusive of VAT
At only £540 + free delivery,I thought this might be a good buy, runs from 13amp
http://www.sipuk.co....o_SIP05302.html
SIP 05302 - Airmate PX3/200-SRB, Belt Driven, Oil Lubricated Air Compressor. 200 Litre Receiver.
SIP 1 Year Warranty.
SIP 05302 Trade Level - Belt Drive Compressor features an extra hard wearing pump unit for long lasting reliability and resistance to wear. Cast iron barrels have finned manifolds to improve cooling and an oversized crankcase for better lubrication. Ideal for heavy prolonged use - the right choice for serious DIY and smaller professional applications. Made in Italy.
Specification;
- 230v (13amp) supply
- 3.0hp (2.2kW) motor
- 200 litre air receiver
- 16CFM (453 litres/min) piston displacement
- Max. Free Air Delivery : 10.7CFM (303 litres/min)
- 145psi (10 bar) piston displacement
- Cast iron barrel
- Multi-finned flywheel for improved cooling
- Oil lubricated
- Weight : 94kg
This one slightly cheaper at £527, smaller receiver, needs a 30amp supply
http://www.machinema...-air-compressor
This compressor must be run from a 30 Amp supply minimum.
- 14cfm displacment - cast iron, twin cylinder air compressor pump
- 150 litre air receiver (CE certified)
- 3hp motor, 230V continuously rated with overload protection
- 10bar (150psi) maximum working pressure controlled by a fully automatic pressure switch.
- Specification also includes safety valve, pressure gauge, air outlet valve & drain tap.
- Application - these air compressors are perfect for professional automotive/industrial use
- Dimensions (LWH) 1390 x 420 x 920mm, Weight 97.5kg
I can also get this one, but not from this site for £575, but is a bit more than I Wanted to pay
http://www.airsuppli...hree-phase.html
• Capacity = 15 CFM (430 Lt/min)
• Max working pressure = 10 Bar (145 PSI)
• Powerful 3 HP (2.2 Kw) lubricated belt driven pump unit
• 150 Litre cast iron air receiver
• Available in Single or Three Phase
• Also known as the ABAC PRO A39B 150 FM3
