i have been offered an engine by a friend that has been split (gearbox, head, engine) and im wondering if its any good to me.
the bores are worn/crudy and it is currently +0.60, (pistons are marked 21251 +0.060) its a pre A+ block (dont know if that makes any difference?)
my questions are.........
1)
if the bores will clean up with a hone, are those pistons any good? (i kinda think they arnt the best from memory as they are low compression jobbies i think?)
2)
assuming i cant hone the marks out, can the block be machined to 1380 and still clean up?
the gap between the bores is currently as follows.....
{front of engine} {flywheel end}
(cylinder1) <---5.1mm gap--->(cylinder2)<---4.4mm gap--->(cylinder3)<---4.8mm gap--->(cylinder4)
hope you can follow my description above!
